Using a ScriptRunner Clone Issue Post Function, how can I set a comment on the cloned issue?
Bert Dombrecht
January 11, 2022
On Jira Software Cloud, I'm using the ScriptRunner Clone Issue Post Function to create a child issue automatically.
In the 'Additional Code' section I can update some fields for the cloned issue, for example:
issueInput.fields.summary = "Prefix " + issueInput.fields.summary;
However, I cannot seem to set a comment on the to-be-created cloned issue.
On Server, this was done as:
doAfterCreate = {
// Add Comment
    // dispatch an event after creating the comment
    final boolean dispatchEvent = true
    // the body of the comment
    final String commentBody = "Auto-generated Issue"
    // the author of the comment will be the logged in user
    def author = ComponentAccessor.jiraAuthenticationContext.loggedInUser
    ComponentAccessor.commentManager.create(issue, author, commentBody, dispatchEvent)
// Update Issue
    issueManager.updateIssue(loggedInUser, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
What is the way to do this in ScriptRunner for Jira Cloud?
I appreciate your help!
Sebastian Krzewiński
January 11, 2022
Hi @Bert Dombrecht
Please check this docs:
https://community.atlassian.com/t5/Jira-Software-questions/Jira-Cloud-ScriptRunner-How-to-add-comments-to-issues-in/qaq-p/1258613
https://www.youtube.com/watch?v=9gppxfiEhxU
Both links are not exactly what you need but you can see an example how to add comment in Jira Cloud.
Seba
Bert Dombrecht
January 11, 2022
Hi @Sebastian Krzewiński
Thanks for your reply.
The information you shared handles adding a comment to an already existing issue.
In that case I can indeed use post("/rest/api/3/issue/${issue.key}/comment")
However, the crux here is that I want to pass a comment to a issue that has not been created yet (during the Clone action), so there is no issue.key yet.
I was assuming I need to use issueInput.update somehow ...
January 11, 2022
Ask Script runner support. Maybe they will have solution for that.
Dimitri Cools
@Bert Dombrecht  ever got any further on this ? I 'm struggling with similar scenario
Bert Dombrecht
March 27, 2024
I'm afraid not...
