Using automation to copy value from summary to custom field?
Patricia Johansson
We have a project for access requests, and using dynamic templates we have created templates where the requester fills in details such as "user email". I would like to get this info copied from the summary to a field we have named "user email".
Using the command:
{{issue.summary.substringBetween("","")}}
This doesn't seem to be able to collect an email address, even if I surround it with ( ), or ' ' or set the rule to include the words before/after.
It seems it will only work on one word, for example:
Bitwarden Access
[rest of summary]
  • Rule ("B","n") gives me "itwarde"
  • Rule ("B","c") gives me none/blank (expected "itwarden A")
Is there a way to get a text like email address from the summary to a custom field?
John Funk
Hi Patricia - Welcome to the Atlassian Community!
Do all of the emails end with .com?
Patricia Johansson
Hi John, they should yes :)
John Funk
Then maybe change it to ends with .com
Patricia Johansson
So this is my issue that it won't return anything if there are spaces, special characters etc, as shown:
Bitwarden Access
[rest of summary]
Even if I set the rule to be "{{issue.summary.substringAfter(":")}}" and change the summary so the user email is the first one with a : it still returns blankimage.png
Log on automation:
John Funk
Well, it looks like there are too many limitations for what you are trying to do. You should probably create a custom field to capture the information when it is input.
Patricia Johansson
So there wouldn't be a possibility of collecting this info from the summary itself? As we do have a field already but want it to autofill from what's put into the summary. As we use templates it should always be in the same format
John Funk
Hmm, in your example above, you have issue.summary, but you show values in the Description field. Does your Summary field have the colon?
Like • Patricia Johansson likes this
Patricia Johansson
Oh my...... You are right, I had confused the description with summary *facepalm.
Thanks! It's one of those things that the longer you stare at them the more blind you become
Like • 2 people like this
Mark Segall
Hi @Patricia Johansson and welcome to the community!
Can you please provide a sample summary so we can see the full context?
Patricia Johansson
Hi Mark and thank you!
Sure, so we use the templates for Jira and here is an example of one of our dynamic templates:
Summary would be something like this based on the above:
Bitwarden Access Request
User email: ' test@email.com '
Manager: Manager
Domain: Supply
Collections:
I've tried surrounding the email address with ( ), *'s, etc.
Even if the rule is set to
{{issue.summary.substringBetween("email:","Manager")}}
and no other formatting is added to the email address it always returns blank
Help us plant more trees
