Sign up Log in
Validate checkbox custom field with Scriptrunner
Danish Hussain Sabunwala
May 20, 2021 edited
Hi Team,
Forgive me if it comes up as a silly question since I am a complete beginner to Scriptrunner. I am trying to add the following validator script to Workflow but getting the following error.
cfValues['Sub-Status']*.value.contains("On hold")
Here 'Sub-Status' is a checkbox field having only 1 value 'On hold' currently.
Could you please help me with the solution?
Thanks and Regards
Danish Hussain
3 votes
Kristian Walker _Adaptavist_
May 20, 2021
Hi Danish,
Thank you for your question.
I can confirm that the reason for your error is due to your validator expression is not valid code for Jira cloud and is groovy code that will only work on Jira server.
I can confirm that inside of Jira Cloud that validators are designed using the Jira Expression Framework and you would need to use this expression syntax to define the validator that you require.
I can confirm that we have a knowledge base article located here which explains how you can use this to create the validator that you want with ScriptRunner for Jira Cloud and I hope this helps to achieve your requirement.
I hope this information helps.
Kristian
Hello @Kristian Walker _Adaptavist_ ,
Thank you for the above links.
I was able to find scripts related to labels, links, discription, sub-tasks etc. but unable to get anything regarding Checkboxes.
If possible, could you provide a code similar to cfValues['Sub-Status']*.value.contains("On hold") for JIRA cloud?
Thanks in advance,
May 20, 2021 edited
Hi Danish,
I have added an example here on line 55 which shows gow to validate that a checkbox field must contain just a single value.
Please note if you need to change this example you will be able to modify this using the Jira Expression framework doucmentation as an example to help you to modify it using the Jira Expression framework doucmentation as a guide to help you to achieve this.
I hope this helps.
Kristian
Thanks a lot for your help. The following code provided the answer I was looking for.
Guilhem Dupuy
May 20, 2021
Hello @Danish Hussain Sabunwala ,
I'm no Scriptrunner expert either, but I think you can achieve what you want without using it !
You could use a simpler validator in your Jira Workflow called "Regular Expression Check". There, you simply have to select your Checkbox field, and enter the correct value the field must have to validate the transition.
Let me know if it helps,
Guilhem
Hello @Guilhem Dupuy ,
If I use 'Regular Expression Check' then I won't be able to provide a custom Validator error message which is also a requirement from the user.
Is there any other approach, please do let me know?
Thanks and regards,
Danish Hussain
Guilhem Dupuy
May 20, 2021 edited
Oh, I see why you were using Scriptrunner then.
Well as far as I'm aware there is no other way to do it, maybe you can manage to display an error message using Scriptrunner ?
May 20, 2021 edited
@Guilhem Dupuy , Yes it will be possible by using Scriptrunner Validators. But still not able to understand the above error.
Guilhem Dupuy
May 20, 2021
@Danish Hussain Sabunwala as I said I'm no Scriptrunner expert I can't really help you with the code unfortunately I was just proposing a work-around :/
The column 24 seems to point to the "." character, but I don't understand why either :/
@Guilhem Dupuy ,
Thank you for your time and response.
It is appreciated a lot.
Like Guilhem Dupuy likes this
Guilhem Dupuy
May 20, 2021
Thanks mate ! I hope you'll find an answer to your mater.
Register Now
Upcoming Jira Events
