Validation: validate that subtask of a specific type is in a certain status for transition
Ricardo Gomes
August 24, 2020 edited
We have to validate and only allow the transition of a parent story ticket when its specific subtask ticket type "Definition of Done" is in "Closed" status. Is that something that I can use JMWE to build a custom validation for?
That validation would occur when the transition screen modal is displayed - if the associated subtask is not in closed status then I'd like to display a message for the user on that modal.
I think I found the answer using the linked issue JMWE validation option but what happens if the ticket I'm validating doesn't have a sub-task with that type (not all tickets have the DoD subtask)? Do I have to add a conditional that checks to see if the ticket in question has that sub-task first?
I tried entering the following conditional but I can't figure out the correct syntax:
!issue.get("subtasks")?.any{it.getIssueType().getName() == "DoD - Definition of Done"}
Please advise.
David Fischer
you can use the "Linked Issue Status Validator" that can do exactly what you're looking for without a single line of code - you can select the link type (Is Parent Of), the issue type of the sub-tasks to check ("Definition of Done") and the statuses these particular sub-tasks need to be in ("Closed").
