Validator if there's any issue in specific status
Gui Ávila
Is there a way to block a transition from status X if there is any other issue in status Y? For example: developers should not transition an issue from Backlog to Progress if there is at least one issue in status Rejected by QA.
Maybe using validators?
Gui.
Vikrant Yadav
Hi @Gui Ávila For this you have to Put JQL condition. If JQL condition met then In Progress transitionwill be visbile, if condition fails then this transition hides for the user.
Gui Ávila
@Vikrant Yadav Thanks!
Like Vikrant Yadav likes this
Fabian Lim
Hi Gui,
We use the JMWE plugin which easily allows you to perform the scenario above. You will apply this validator between the Backlog and Progress transition.
Here is the link with the details: https://innovalog.atlassian.net/wiki/spaces/JMWE/pages/1155957033/Linked+Issues+Status+Validator
Fabian
Gui Ávila
@Fabian Lim Thanks!
Gui Ávila
@Fabian Lim Hum... the validator you suggested is for "linked issues". What I'm looking for is to check if there is any other issue for the same assignee in the status "Rejected by QA", for example. If there is at least one, no other issue for the same assignee should be authorized to move from Backlog to Progress.
