Variable to collect assignees from sub-tasks, using lookupIssues not working
isabel_p_cardoso_hotmail_com December 10, 2024
Could someone help me with variables and this lookup formula, please? I am new to advanced automation in Jira. I am trying to trigger this automation, everytime a sub-task changes assignee. The ideia is to have a variable that will store all assignees from the sub-tasks and then apply that to the story that is linked to those sub-tasks, but the variable does not seem to be collecting anything.
Is it probably a sintaxt issue, but I have no idea what could be. Also, if possible, can someone advise me how I collect those names so that it does not repeat same assignees? Something like a distinct function? Thank you so much.
Marc - Devoteam
December 10, 2024
Hi @isabel_p_cardoso_hotmail_com
Try the following:
If an  issues is "Unassigned" no value will be shown in the log.
isabel_p_cardoso_hotmail_com December 11, 2024
Thank you Marc. I was able to create a variable called {{resp}} and save the assignee names there but now I can't update the user story field Developers Assignee with the information in the variable {{resp}}.
I am stuck on the sub-task that triggered the action, which is the IP-16, and the error is that this issue does not have the field developers Assignee... which is right. Only the User story has this field.
Marc - Devoteam
December 12, 2024
The rule I presented you triggers on a sub-task, then it finds the parent of the sub-task and the lookup finds all sub-tasks, based on the found parent.
isabel_p_cardoso_hotmail_com December 13, 2024
Yeah.. I noticed that after not being able to add the variable into de parent issue (User story)... so I believe I need to start the branch with the branch : For Parent, but then the whole structure of lookups changes. I managed to do a lookup but got all the issues of my project (epics, user stories, sub-tasks)... I just can't seem to get a lookup formula that would get me only the sub-task of the parent issue.
Duc Thang TRAN
December 10, 2024
Hello @isabel_p_cardoso_hotmail_com
I think using a lookup to check if the task has more than one subtask can display an error.
I suggest using this approach
2024-12-10 14_19_29-Audit log - Automation - Admin Jira - Test - Jira — Mozilla Firefox.png
Best,
FREE
