Visually mark issues with subtasks on kanban board?
Sabina Alistar
We are using a kanban board grouped by Epic. Some issues have sub-tasks, but we chose not to show sub-tasks on the board since it gets too messy.
Is there a way to highlight issues that have sub-tasks so we can more easily see which ones require a deeper look?
I thought of using colors to do it, but I need a JQL query to identify issues that are "parents", and apparently there's no easy way to do that.
I'm won't be able to use any add-ons or external apps to do this.
tokcum
October 13, 2020
Dear Sabina,
I'm afraid there is no simple solution to your request. I would like to point you to this feature request.
JQL to filter issues with/without subtasks
There you find a bunch of workarounds, some of them pointing to a similar direction as Jack.
Please vote for this suggestion. So it gets more traction at Atlassian.
Thanks and kind regards,
Tobias
Jack Brickey
October 12, 2020
one idea (not really pretty but should)...
  • Create a custom field called say "Parent-Issue" that is either none (default) or "Yes"
  • Create an automation rule: trigger on issue created, condition of JQL issuetype=sub-task, action - set the Parent-Issue" to Yes for the parent of the current issue
  • use JQL to color the card based upon Parent-Issue = Yes or simply add the field to the card.
holes in this: if you delete all sub-tasks then you would still show the original parent has having sub-tasks. if you move an issue from a task to a sub-task the automation would not pick it up.
Register Now
