Hello Jira support team,
Currently, I am using the WBS Gant chart Add on instance for Jira projects.
Please can you tell me in WBS Gant chart if there is any way using which the duration for the sub-tasks are auto calculated from the estimation assigned to the Jira User stories or sub tasks?
Or do I have to manually enter the days/duration for every story/sub-task?
It is very time consuming, would like to know if there is any easier way as the estimations keep changing & one has to manually enter the duration for the stories/sub tasks every time.
Awaiting your response.
Rutuja.
You can update your Gantt configuration in order to fulfill your requirement.
Please follow the steps below to automatically adjust the Duration values.
Click on the gear icon (Gant configure) > Select Gantt configuration
I hope this helps to answer your question.
