WORKFLOW PROBLEMS!
MANUEL VARGAS ESTRADA September 25, 2020
Hi guys...
I created a Project, then I created many Boards...then a Task and many Sub task...But I dont know why when I Approved a Sub Task the whole board selected transition to approved (see the image).the order correct must be..
Board Number 1:
Open 2
Approved 2
Under Review 2
But the whole board appear on Approved stage..how can i do in order to correct this?.
John Funk
Hi Silvio,
It sounds like you have some automation that is moving cards based on the status changing for a Sub-task. Take a look at the history of the cards that moved but shouldn't have to see who it said moved it.
Niranjan
September 26, 2020
Kindly check if there is a postfunction in sub-tasks's workflow.
MANUEL VARGAS ESTRADA September 26, 2020
I see everything is ok..I really don't know what to do!
