For my stories I would like to display Grandparent just like how the parent issue is displayed, how can I do it? Do I have create a custom field?
Hello @Monica Gupta
There is no pre-built field for displaying the "grandparent" issue key for an issue.
You could create a text field and use an Automation Rule to populate it.
can you guide how that automation rule will look like?
