  • Community
  • Q&A
  • Jira
  • Questions
  • We couldn't connect to that issue Make sure that this issue actually exists in that project. If it d
Cihat Haktanır November 11, 2019
Hello, I get backup of my jira. And I only changed some issues created and updated date in entities XML file. I did it before. After that I imported my documents to jira with Merge with existing cloud users method. And now when ı tried open issues I get a error message like that:
Make sure that this issue actually exists in that project. If it does, try again in a few minutes. If you still can't link to the issue, contact your Jira admin.
All my issues and projects are seen no problem but when I tried oped issues I got an error message. Please help me.
I solved problem.
Muhanad Znbrakji
February 7, 2020
Hi, I am having the same problem. How did you solve it?
Thanks in advance!
Like NIKOS KARANIKOLAS likes this
Jan Anderson
February 20, 2020
Hi.  I'm having the same issue with a stakeholder who needs update issue.  How can you tell if you your issue exists, other than hitting the link and going in there ok.
Muhanad Znbrakji
December 15, 2020
Finally I issued a support ticket by Jira and they solved it for me. Apparently it was an internal bug.
Charl Brill
March 12, 2021
I'm still getting this issue some times (most of the time). Please can someone suggest a solution to this issue?
Carolina SILVA
March 24, 2021
hello same on my side, a user created 2 issues, they were accessible and after some days, no more access.
The error message is the same WE COULND'T CONNECT TO THAT ISSUE
I'm an admin, and when I'm login with its access, everything is accesible
Atlassian bug?
