I have added webhook events on all transitions i want notifications in slack.comon. But I'm not getting any updates. Can anyone please assist?
I previously had "all events" checked, but then I only got notifications when resolution status was changed, which is why i added hooks for transitions instead.
These are the settings for the webhook: http://imgur.com/1HzU2vj
Hi, we really need to be notified of JIRA issues comments on slack. is it possible ?
I filed a support request with Slack.com and got this answer:
"Our JIRA integration will currently only post events when:
{snip} We're planning to add more events in the future, sorry for the current limitations.
There are all kinds of events listed in JIRAs webhook settings, yet, none of them seem to trigger the slack webhook
Same for me - webhook works only for issue creation / resolution (from default settings) but is not triggered as a post transition event.
+1 experiencing the same problem
@David Nicholson [Atlassian] Is there any news on this issue? Is this a JIRA or Slack problem?
To add further to this, I just pushed a very minimal ticket through a transition that would trigger the hook and it showed up, so it seems like there's a limit on the size of the JSON body.
@David Nicholson [Atlassian], I'm seeing the same problem and I used http://requestb.in to test the webhook. The webhook is definitely triggered, but the JSON payload is truncated, which is why I assume nothing shows up in Slack. Can you take another look into this please?
This seems to be an issue with Slack, you can confirm that the webhook is firing by using http://requestb.in/, however it is not getting handled on the receiving end.
After updating to JIRA version 7.3.3, our JIRA -> Slack integration via webhooks has stopped working. I've used requestbin to identify any potential issues with the request.
It appears the the request payload is being truncated to 7495 characters, meaning that the json being sent to Slack is invalid. Is this an known issue?
JIRA / Slack integration issues is caused by a bug in JIRA HTTPS Webhooks. Upgrading to JIRA 6.4 fixes it.https://jira.atlassian.com/browse/JRA-44769
I tried to setup an integration with a WebHook today but it doesn't work, requestb.in shows the JSON payload is cut short, seems like a JIRA problem??
Our integration was working fine but when we changed to a different slack channel, it stopped entirely. We have re-created the integration several times with no success in restoring the feed. Not much help, but more evidence that there still is a problem.
Take a look at Jirassimo notifications for JIRA, it has integration with Slack among the other messengers. You can choose events or can make a scheduler to have own event and use it as a reporting service.
Would love to see this Webhook released... It would make JIRA more friendly with non-JIRA teams...
Simply created in Python.
JIRA Webhook -> Flask -> Slack Incoming Webhooks
We have JIRA and Slack integration work intermittently. One week JIRA sends the full payload over to Slack, then stops another week.
Moving to github solved the issue for me
I had same problem, so I made hubot do that for me.
https://github.com/mnpk/hubot-jira-spy
JIRA hook hubot, and hubot chat the comments to slack.
Any solution on this. We also have the same problem. Nothing shows up in slack.
We have the same problem, we couldn't even get comments to show up in HipChat either. It seems like a JIRA limitation.
How can i select a specific board to be integrated with slack, as currently we have alot of board in the same project ?
had the same issue. Make sure on the SLACK side that you check the "Additional Notifications" section for "new Comments"
Has there been any update on this?
I have used the Slack JIRA integration and the appropriate steps on the JIRA Cloud side of things (as per Slack guide). I've set a filter and on issue creation and update. New issues trigger a notification into slack; however, issue updates are not generating a notification.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
