What am I missing? Attempting to create workflow with transition rules.
Antony Chea
December 8, 2021
I am currently calling the JIRA workflow API to create a new workflow. The goal is the ability to fully configure JIRA for projects automatically.
"/rest/api/2/workflow"
 I am able to currently create the JIRA workflow with a post call and the following payload.
workflow_payload = json.dumps({
"name": "api_workflow",
"description": "This is a workflow created through API.",
"statuses": [
"id": jf.get_workflow_status_id(url_base, headers, 'Open'),
"properties": {
"jira.issue.editable": "false"
"id": jf.get_workflow_status_id(url_base, headers, 'In Progress'),
"id": jf.get_workflow_status_id(url_base, headers, 'Reopened'),
"id": jf.get_workflow_status_id(url_base, headers, 'Resolved'),
"id": jf.get_workflow_status_id(url_base, headers, 'Closed'),
"transitions": [
"description": "",
"from": [],
"name": "Create Issue",
"to": "1",
"type": "initial"
"description": "",
"from": [
"1",
"3",
"4"
"name": "Close Issue",
"rules": {
"conditions": []
"to": "6",
"type": "directed"
"description": "",
"from": [
"5",
"6"
"name": "Reopen Issue",
"to": "4",
"type": "directed"
"description": "",
"from": [
"3"
"name": "Stop Progress",
"to": "1",
"type": "directed"
"description": "",
"from": [
"1",
"4"
"name": "Start Progress",
"to": "3",
"type": "directed"
"description": "",
"from": [
"1",
"3",
"4"
"name": "Resolve Issue",
"to": "5",
"type": "directed"
"description": "Closing an issue indicates there is no more work to be done on it, and it has been verified as complete.",
"from": [
"5"
"to": "6",
"type": "directed"
I had written function (jf.get_workflow_status_id(url_base, headers, 'In Progress')) so that users can provide status name and retrieve the ID. In the example above, user provides "In Progress" and in its ID will show up. I am able to create workflow with transitions from one status to the next. However when I attempt to add rules/conditions, etc I get thrown an error.
"rules": {
"conditions": []
{"errorMessages":["Can not deserialize instance of com.atlassian.jira.workflow.bean.create.CreateWorkflowConditionBean out of START_ARRAY token\n at [Source: org.apache.catalina.connector.CoyoteInputStream@5c6936c; line: 1, column: 392]"]}
Can anyone explain what this means? What I need to change? I initially copied a condition from a workflow I created through the UI, but that didn't work, so I kept removing things inside the bracket to the point, even without anything in it, it throws that error.
I am able to create a workflow where I provide a blank validator.
"rules": {
"validators": []
Let me know if any details is required. Shocking that following the example from "https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-workflows/#api-rest-api-3-workflow-post" didn't do anything or work.
Alex Koxaras _Relational_
January 3, 2025
Hi @Antony Chea and welcome to the community,
There is a new endpoint for creating workflow, Bulk Create Workflows. Can you try with this https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-workflows/#api-rest-api-3-workflows-create-post and let us know if that resolved the problem?
FREE
