What are all the required fields to create an issue in team managed projects ?
BURMA RAJASHEKAR October 11, 2021
Suvradip Paul
October 11, 2021
Hi @BURMA RAJASHEKAR ,
Thanks for posting.
I would suggest you to go through this doc - https://support.atlassian.com/jira-software-cloud/docs/customize-an-issues-fields-in-team-managed-projects/ and check the default fields sections and if you are also interested in custom fields then check create and edit custom fields.
Please let me know if that helps.
Cheers
Suvradip
Jack Brickey
October 11, 2021
Hi Burma,
I am not sure I understand your question. Required fields are defined by your project admin. We in the Community do not have knowledge of your project  details. Can you please restate your question?
which are the fields must needed to create an issue in team managed projects ?
Its not about making fields required in field configuration. Hope you understand!
Jack Brickey
October 11, 2021
I’m still unclear but let me say that the only required field for any basic TMP project is Summary. Anything else will need to be configured by the project admin.
Like Nic Brough -Adaptavist- likes this
Jack Brickey
October 21, 2021
Hi @BURMA RAJASHEKAR , first if the original question has been answered you should consider accepting the answer that best resolved your question. Second, you should always consider a separate post for unrelated questions.
I can’t suggest the best course of action without mor info about your use case here.
October 21, 2021
That was an exam question which should not be posted publically.
Like Jack Brickey likes this
