I've created a filter that captures issues for which the current user is a Reporter or Assignee. (I assme Assignee will only yield a result if the current Assignee is the current user.)
I think there are no roles and no groups currently in our Production instance, although I'm going to find out for sure. In the meantime, are there other non-custom non-role fields that capture whether the current user interacted with the issue? Last status changer? User who resolved the issue?
@Phil Bustin if you're looking to add columns to a search that would show things like 'Last Changed By' or 'Resolved By' they are not built-in fields. You can create custom fields for this purpose and populate them with automation triggered by an update or a status change if that's data you'd like to see in a search, otherwise to see this level of detail you would need to go into each issue individually.
If you're looking for a last updated by JQL function, this document shares some of the advanced search functions availble including updated updatedBy(): https://confluence.atlassian.com/jirasoftwareserver081/advanced-searching-functions-reference-970611548.html
I hope this answers your question.
Mathew
