What is the best way to use JQL to find text in the title of a Jira issue?
prasannjeet
April 1, 2020
A simple jira advanced search can be something like:
text ~ "feature-55" AND type in ("New Feature","Improvement") ORDER BY created DESC
However, I think the string feature-55 will be searched in the complete jira issue. Is there a search query through which I can only search for the text in the title of the issues?
14 votes
Ashkan Malekly
April 1, 2020
Hi @prasannjeet
Yes. As bellow:
Summary ~ "featur-55"
Souro
Hi Ashkan,
I have a use case. I want to search for Jira tickets that have 'ABC' or 'XYZ' in titles. It's not necessary to have both 'ABC' and 'XYZ' in the same ticket title. Is there a search syntax that will give me all the possible tickets that have 'ABC' or 'XYZ' in titles? Thanks in advance.
James August 24, 2022
@Souro , you can use the OR function in your search query, e.g.
Summary ~ 'ABC' OR Summary ~ 'XYZ'
Like # people like this
med jamac
October 20, 2022
  • A
Like Richard BIGOT SCOARNEC likes this
Cesar Arias Canto
December 14, 2023
I'm getting the following error
The text query '[FE]' for field 'summary' is not valid: probably your range query is incorrect.
I'm searching:
summary ~ '[FE]' AND project = XXXXXXX AND issuetype = Bug AND status in ("To Do", "To do") order by created DESC
James December 15, 2023
@Cesar Arias Canto unfortunately that's a known issue with JIRA filters and there's no apparent workaround. See https://jira.atlassian.com/browse/JRASERVER-25092.
Frederik Voordeckers
January 10, 2024
This worked for me:
summary ~ "\"[FE]\""
FREE
