From Atlassian Support, this is the correct Smart Value:
{{issue.fields.project.projectCategory.name}}
Awesome! Thanks for sharing this!
Ste
Thanks, @Joe
I hope that the smart value documentation will eventually centralize this information and align it with the REST API output.
__Bill
can't get it to work, can anybody tell me how exactly this is supposed to be implemented in an automation?
Ok seems to be because i'm coming from a release trigger.
if you are coming from a release the smart value is as follows:
{{version.project.projectCategory.name}}
Thanks, @Wim Matthijs
I really wish there was a comprehensive smart value glossary: https://jira.atlassian.com/browse/JIRAAUTOSERVER-103
Rule writers waste lots of time hunting around for answers and the correct context to get at the information in Jira.
Actually a simple microservice doing autocompletion would be awesome 😎
Yes, lots of opportunities to improve the automation rule editor. I'd like at least some syntax validation prior to save. (another example: Watch out using RegEx in rules, as some invalid expressions lock up the rule editor when the engine attempts to parse them, preventing a save!)
Thanks for the pointer, didn't use regex so far yet, and will be careful when i do!
EDIT: Text-based matches for these smart values may be case-sensitive for cloud automation rules that are triggered by create issue. If your rule recently started failing, it might be due to that, rather than a change to the smart value logic itself.
Hi @Alis-Hathway Ward (DO NOT USE)
I just retested this one and it works for Jira Cloud when the context is an issue and the project has an assigned Project Category. Otherwise it returns null.
{{issue.project.projectCategory.name}}
Very strange. It's certainly not working for me. Is there something super obvious to you that I'm not seeing wrong with my rule? I'm the site admin, so I can confirm with 100% surety that my category drop down includes choices for both hybrid and native and that the option is selected in the project config.
Audit:
IF BLOCK
The following issues did not match the condition:
IF/ELSE BLOCK
When: Issue created
Rule is run when an issue is created.
If: matches
{{issue.project.projectCategory.name}} contains hybrid
Then: Edit issue fields
Components
Add component
Else-if: matches
{{issue.project.projectCategory.name}} contains native
Components
Add component
I was able to get it working when I inspected the drop down list and passed instead {{issue.project.projectCategory.id}}.
I don't know why that works and not name, but I will take it. My guess is case-sensitivity, which I've noticed JIRA has lately cared about for certain query params.
Thanks, Bill, for the help.
I am glad to learn you got that to work.
One more thing to try if you still want the name attribute: The Issue Created trigger can start the rule before all of the data is available. This is a known timing issues for Jira Cloud.
The work-around is to add a Re-fetch action immediately after the trigger. This will slow down the rule and reload the issue data before trying to use it.
Hi @Joe
Please try the guidance below to find an unlisted/undocumented smart value, using the REST API to capture an example issue:
https://support.atlassian.com/jira-software-cloud/docs/find-the-smart-value-for-a-field/
Note that if this does not provide an exact match, it may get you close enough to experiment and find the name.
Best regards,
I could never get {{issue.project.projectCategory.name{}}} to work either. Used correct case, tried in quotes, without quotes, stood on my head, etc.
I gave up and did {{issue.project.projectCategory.id}}. It's now working.
Hi @Celina Kincaid -- Welcome to the Atlassian Community!
If you did try this:
The reason that did not work is the extra curly brackets after name. Please try this instead:
Any update on this one?
I have tried LOTS of different iterations and can't get anything to pull back the Project Category.
YES {{project.name}}
NO {{project.projectCategory.name}}
NO {{project.projectCategory}}
NO {{project.projectCategory()}}
NO {{project.projectCategory.name()}}
YES {{issue.project.name}}
NO {{issue.project.projectCategory()}}
NO {{issue.project.projectCategory.name()}}
NO {{issue.project.projectCategory}}
NO {{issue.project.projectCategory.name}}
NO {{issue.fields.project.projectCategory.name()}}
NO {{issue.category}}
NO {{issue.category.name}}
NO {{issue.category.name()}}
NO {{issue.project.projectCategory.id}}
Hi @Amy McCann
I just tried...
...and it works for me.
Assuming you've checked the Project has a Project Category, could you give us the full rule details so we can try to replicate your issue?
Ste
Hi @Joe
I envision it's something like {{project.category}} if it exists - or perhaps {{issue.project.category}}?
How are you looking to utilise the category? If you provide more specifics about the rule, it'll help us find a solution to your overall need :)
Ste
I've tried both of those and neither of them work.
I'm not looking for advice on how to come up with a solution to my problem. I'm just asking a simple question:
Is there a smart value for the project category field?
For context, the JQL syntax for this field is "category."
Hi @Joe
If isn't working with the options I suggested above - I tried them also in a test instance - it might not be available.
{{issue.project.XXX}} is how you access an issue's project information via smart values.
I know this is Server documentation, but this page on Smart Values doesn't mention it under the "issue.project" section.
Ste
