I am new to Jira, I am trying to write a script using the Jira API's for Jira Cloud which will help me in copying the settings of one tenant to another tenant. Here are the different objects that I am planning on copying over:
Does the above list cover all the different objects that I would need or am I missing anything else?
Any pointers to sample scripts using the REST API's would be super helpful.
Thank you.
Hi @Vish
Issue Security Scheme, Components, Permission Scheme, Notification Scheme, Priority.
You have to see the Project and decide on what objects they are using and then decide to export. If you are trying to move whole configuration settings, Configuration Manager for Jira is rolling out for Cloud.
Please reach out to them for more info
Pramodh
