When I edit a username, comment mentions do not update
Chris Bell
After renaming an existing user, JIRA does not update the reference/mention to that user in comments. Is this intentional or, as part of a site re-index, could JIRA automagically update the username as mentioned in the comment.
alfianabdi
December 10, 2019
We have some problem after integration with Azure AD, basically we rename all user to use their email address as the new username, but all mentions are gone. Is there any way to solve it?
Jennifer Ward January 24, 2020
we have that exact situation too- switched to Azure AD, some, but not all historical @mentions are broken
Any luck on a resolution?
Tihomir Nikolov _Nemetschek Bulgaria_
We faced the same problem after integration with external LDAP server and renaming users, all the mentions are broken.
Is there a workarround besides replacing all the stuff in the database ?
Cheers, Tihomir.
Paula Silveira
June 10, 2015
Hi Chris,
It seems this issue is related to JRA-35102.
Thanks and regards,
Paula Silveira
