As in the topic, when importing a CSV, it does not search for the project I just need. Some other projects are displayed, but not the one I need.
Hi @Krzysztof Matlak ,
Please check if you have sufficient permission to create the issues in the project. Check the permission scheme and then check if you are added in that particular tole Or not.
It worked, but a small note, it is not worth importing using a csv file. :)
