When sub-task is merged transition its status to DONE
Hala Haneya
September 8, 2025
I have this rule that keeps failing. It is not detecting the work-time type to be subtask as expected
RULE:
ERROR:
September 8, 2025
Hi @Hala Haneya -- Welcome to the Atlassian Community!
Your rule is trying to use a JQL branch, but the JQL expression is invalid.
To use the Pull Request Merged trigger for your scenario, please see this template rule in the rule list:
When a pull request is merged → then move work item to done
And if you only want that to apply to Subtasks, you could add another condition after the trigger.
Hala Haneya
September 8, 2025
Hi @Bill Sheboy
Would this work?
Like Bill Sheboy likes this
September 8, 2025
Yes, that should work for the scenario you described.
Have you tested with it yet?
Like # people like this
Hala Haneya
September 9, 2025
Yes, it works now. Thank you for your support!
Like Tim Kopperud likes this
Gor Greyan
September 8, 2025
Hi @Hala Haneya
Welcome to the Community!
Try not to put a branching rule; apply a condition that will check if the triggered issue is an exact sub-task or it is belongs to sub-task type.
Use the second logic to put the automation exactly for the issue type "sub-task" and use the first one, if you want to put it for all types of issues that are sub-tasks1.2.png1.1.png.
