when it was simple work flow, it worked like the same, but now its not working and constantly showing some error, please help how i can proceed this, Find the attachment below,
Hi @NANDHANA_VAZ - You'll need to review the parent workflow. It is likely one of two things has occurred:
So, you'll need to do a little bit of digging to see what changed in the parent workflow in order to adjust the rule accordingly.
before the condition is when issue transmitted from pending for approval to done , now i have changed only to done i left the blank, and also if the done status is with the all status the automation is fine, if not it is working
Is it possible for you to share a screen shot of the workflow? This would help better understand what adjustments need to be made.
Ok - So this is a team-managed project, correct?
It appears that PENDING FOR APPROVAL is still the only status that can transition to DONE. So, you'll need an issue field condition in your branch:
status = Pending For Approval
Without the condition, the rule will fail any time the parent status is something other than that.
Like this you meant, please correct me! i was trying to sort out this for quite long time.
Yes - That should work.
Let's take a step back. Can you please clarify a couple things for me?
1. there is different issue type as task and linked to subtasks and iam using only one work flow!
In that case, I can't see any further issue with the rule. Are you still getting the same error in the audit log?
Getting the status as No action is performed, what can be done now? please guide!
It is exiting out because the parent issue is not currently in the status PENDING FOR APPROVAL.
Is your intention to have the parent transition to Done regardless of status? If so, you'll need to tweak the workflow to support that type of transition.
yeah, i checked and corrected it worked, thank you.
(Since it is mentioned as pending for approval to done status, main task should be in pending for approval, then it is transited done automatically. and for moving to IN progress and pending for approval i have made other automations, which is working perfect)
