×Hi all,
I took over from a departed employee and one of my board obviously has rules overlooking what is happening in the board.
For example: Putting a ticket in a specific column automatically assigns it to a user.
Now I need to modify this behaviour but when I go to my Board - Automation page, I do not see any rules that I can modify, everything is empty.
Is there somewhere else these rules could be?
TIA
Michel
Hello @Michel Lemieux,
The post function can be checked directly on the transitions on the workflow.
Please, go to Project settings > Workflows > Click to edit the workflow.
Select the Diagram mode > Click on "All" for the desired status > Post functions.
On the next page, you will see the post functions and you can remove or edit the one that assigns the ticket to a user.
After editing, click on "Publish draft".
If you have any other questions, please let us know.
Angélica
Hi Michel,
This is related to the Workflow Transition with Postfunction or Automation,
Both of them you can find under "Project setting".
Hi Cristian,
Thank you for your quick response.
I must be missing something because I do not see anything relevant under Workflows or Automation and see no reference to PostFunction.
