Where do I see why an automation rule failed to be enabled?
Glenn A
November 21, 2024 edited
I'm trying to enable this simple rule:
Screenshot 2024-11-21 at 15.37.31.png but get the following error when I try to enable it:
We couldn't enable your rule
Check the rule's configuration and try again
If I look at the audit log, I see nothing. Where do I see why I cannot enable it?
3 votes
Glenn A
OK, seems it must've been a service related issue? No changes and it works now? Sorry for the interruption, we now return to your normally scheduled programming.
Salih Tuç
November 21, 2024
Hi @Glenn A ,
You probably has some errors on any component in automation rule. Can you share details (screenshots) of your "THEN" action and the "Rule details" screens?
It can be because of a wrong usage of a smart value or any other functional problem. Send us the details and let's investigate it together!
