What are the circumstances when a user account becomes de-activated
We have a user account that has api token generated. The account is only used through api tokens, not by logging in.
This account becomes inactive and the api tokens no longer work, can this be stopped from happening
Grant
are you asking about user accounts under admin > user management? I have never seen them being deactivated by any other means than an admin. Have you looked at the admin > system > audit logs to see if there is any clue? Do you have more than one admin and if so have you discussed w/ each?
I am on cloud and I don't think I can see logs. Yes, we have more than one admin and no, no one has done anything. I wondered if there was a setting that revoked access after x days inactivity or something
That is right, thee are user accounts I created
there are limited logs you have access to (check the aforementioned location) and it does include actions associated w/ adding/deactivating accounts. To be clear are you saying you have a user that is "active" and later you go into User management and they are shown as "inactive". Or something else. There is nothing in the SW that automatically deactivates the user. Once you have done all the sleuth work you can including looking at logs I would refer you to Atlassian Support as they can log in and do more inspection.
