After adding Checked and Unchecked options to a custom checkbox field, wondering why the options aren't mutually exclusive, and posting that question to the Community (this post), I realized that the field should not have options. In a different app, checkboxes are binary fields, but I that is not the case in Jira.
I switched to a radio button, and added one option, so that the button behaves like a binary checkbox--IF I can hide the built-in None option. Can that be done?
Hi @Phil Bustin
Would you please clarify what you are asking/observing? Thanks!
Checkboxes are normally zero-to-many selections, and Radio Button options are one-and-only-one selections, which matches the custom fields that can be added to Jira: https://confluence.atlassian.com/adminjiracloud/custom-fields-types-in-company-managed-projects-972327807.html
For company-managed projects, there is a known problem for custom field, radio buttons which are configured as required with a default value, as they still show a "none" option when they should not: https://jira.atlassian.com/browse/JRACLOUD-75541
Thanks, Bill. I was asking exactly what you addressed. I found a possible workaround yesterday to hide 'None'. Here's an extract from it that I saved:
//Grab appropriate managers
def cfManager = ComponentAccessor.getCustomFieldManager()
def optionsManager = ComponentAccessor.getOptionsManager()
//Grab form and custom field values
def selectCF = cfManager.getCustomFieldObject("SelectListA")
def selectField = getFieldByName("SelectListA")
//Must grab the relevant config given the current issue context and the custom field
def config = selectCF.getRelevantConfig(getIssueContext())
//Given config, grab a map of the possible options for the select custom field
def options = optionsManager.getOptions(config)
//Define preset multi select options for each single select case
selectField.setFieldOptions(options.collectEntries{[(it.optionId): it.value]})
Of course you'll want to change "SelectListA" in this script to the actual name of your field.
Josh
Mattias Kallvi Dec 13, 2018 • edited
Hi Joshua,
Thanks for your script. After a minor change to it (used the field id instead of the field name) it works perfectly. Maybe I have to use id since we have Swedish characters in the field name, not sure. However, this is how thoses lines look now:
def selectCF = cfManager.getCustomFieldObject("customfield_12345")
def selectField = getFieldById("customfield_12345")
