Why do my quick filters, which use 'assignee', show a GUID rather than the users name
Paul Treadwell
I can create the quick filter and type the user's name, but once created it shows the GUID in the JQL column
e.g.  assignee = 5fdb25e091bb2e010819ec65
Jack Brickey
This is a result of GDPR requirements. gdpr-changes-to-usernames-in-jira-cloud
June 28, 2021
Hi @Paul Treadwell  -- Welcome to the Atlassian Community!
Yes, and... to Jack's answer: One work-around to keep the name visible in your quick filters is to use this syntax: assignee IN ("Paul Treadwell")
Best regards,
Like • 4 people like this
Paul Treadwell
Thanks for that really useful approach. Works for me.
Like • Bill Sheboy likes this
Darren Newberry
Being new to cloud I had just started facing this issue.
This was very helpful.  Thanks
Paul Treadwell
It works fine on the board but not very helpful to see the GUID.
