  • Community
  • Q&A
  • Jira
  • Questions
  • Why isn't description, acceptance criteria being imported with Jira Cloud for Sheets connector?
alvin.oh December 23, 2024
Hi, i'm using the Jira Cloud for Sheets and am trying to import stories into sheets but when I add fields such as Description and Acceptance criteria, no output comes.
Can someone advise on the fix for this ?
MobilityStream
December 24, 2024
Hi @alvin.oh ,
There has been a recent change to Jira Cloud for Google Sheets & Jira Cloud for Excel by Atlassian. This seemed to have caused all sorts of side-effects that people have been reporting, basically making it unusable for some people. However, even before many user-reported issues and increased system unreliability. These tools are in maintenance mode and very low priority for Atlassian (background here).
If reliable exports are important to your business, we recommend to try our Google Sheet Integration / Excel Online Integration add-ons. They work fundamentally different by exporting directly out of Jira via API calls.They are much more reliable and used by the largest organizations. Exports can be one-time, scheduled, or real-time You can also export much richer data to create more sophisticated reports (for example Assets, Changelogs, Worklogs, Projects, Sprints, Users, JSM customers). Everything is directly controlled within Jira. Give it a try.
The Mobility Team
alvin.oh December 25, 2024
Hi @MobilityStream ,
While I appreciate you sharing me on the background here for the Jira Cloud for Google Sheets deprecation & the recommendation -Google Sheet Integration / Excel Online Integration , I would kindly like to enquire further:
  1. If the app is deprecated , why do we still receive updates as of 16 Dec 2024?
  2. Because of this update, a bug is caused,  and shouldn't the app be fixed to at least it's original state since the app is still being publicized in Google marketplace - https://workspace.google.com/marketplace/app/jira_cloud_for_sheets/1065669263016
  3. Whilst the recommendation is good alternative and i've raised a request to my admin for the installation of it to my org, but I would prefer to keep the Jira Cloud for Sheets as i'm using it for numerous reporting and planning already. It is difficult to decouple as alot of the reportings I have are very reliant on the data import from the Jira Cloud for Google sheets app itself.
Thus, I'd kindly appreciate if the team to take a look into just fixing the bug and as i've only just come to understand on the deprecation notice and will look to slowly migrate to the recommended app over time.
@James Awuah  )
MobilityStream
December 25, 2024
@alvin.oh ,
The app you are currently using has been created by Atlassian. It is not an app by Mobility Stream, we are just pointing out an alternative.
1. This is a question for Atlassian, as it is maintained by them.
2. Please create a ticket for Atlassian support: https://support.atlassian.com/
3. Makes sense. Atlassian might help you to make it work again, if not, you have an alternative.
The Mobility Team
Like Valerie Knapp likes this
thanks for the feedback but I tried to raise a ticket in  https://support.atlassian.com/ but I can't find the right option (see screenshot attached)
Can you kindly please guide me to the the right path or PIC?
Valerie Knapp
Hi @alvin.oh , thanks for the screen. Please select the second option and submit the ticket. If there is any ambiguity about why you are opening the ticket, you can resolve that with the agent after the ticket is opened.
Best wishes
alvin.oh December 29, 2024
Hi @Valerie Knapp
I just got back from leave and I just saw the connector is extracting the info correctly as intended already. i'll monitor in the next days to see how it goes :)
Thanks.
Valerie Knapp
Hey @alvin.oh , welcome to the Atlassian Community and thanks for your question.
Please can you clarify which app you're using?
For example, if you're using this app, https://marketplace.atlassian.com/apps/1225926/google-sheets-for-jira , I would recommend you to check out the product documentation or open up a ticket to the vendor to ask for help https://appsplus.atlassian.net/wiki/spaces/SUPPORT/pages/1323958279/Embed+Apps+for+Confluence+Jira
Best wishes
James Awuah December 24, 2024
It's this Google Sheets app from Atlassian. I am running into the same issue.
Like alvin.oh likes this
