How do I configure the two-dimensional report column widget to sort by Issue Status Category; Todo, In-Progress, Done
Todo
1. TODO
2. BACKLOG
In-Progress
3. IN PROGRESS
4. IN REVIEW
5. WAITING FOR QA
6. IN QA REVIEW
Done
7. CLOSED
8. READY FOR RELEAS
9. DONE
Hello @Michael Bevilacqua
Welcome to the Atlassian community!
The ordering of statuses on that axis is determined by the ordering of the Statuses in the Global configuration (for statuses used in Company Managed projects). If you click the gear icon near your avatar and select Issues, then find the Statuses list, you can reorder the statuses there and that should affect the ordering in the gadget. It also affects the ordering of Statuses shown when a user is changing an individual issue status, and when using ORDER BY Status in a filter
