Export Not Populating 11/4/21 where we want the time spent to be recorded.
NOTE: This is a "Subtasks" issue type. I am using subtask to log our time. This Subtasks does roll up to an Issue type = User Story AKY-310.
Possible Workaround: https://jira.atlassian.com/browse/JRASERVER-64025
SIMILAR ISSUE:
DESIRE: is for REST API and/or CSV all fields export/extracts to include Started date field from the Time Spent Log Work, which is working as expected within the "Timesheet Tracking for JIRA" add on. For outside JIRA reporting, I have to extract from REST API or CSV PLUS Timesheet Tracking For JIRA for the "Started" date entries/records.
REFERENCE:
https://louisv.atlassian.net/rest/api/3/search?jql=filter=10014
Timesheet Tracking for Jira
Hi Louis,
The datetime in the UI is adjusted to align with your timezone. The export shows the datetime in alignment with the applications System Time. This is normal and expected. Cheers!
JIRA UI ("Date Started") = 11/4/2021
I explicitly retro back the date, trying to leverage the Date Started field to when the "Time Spent" was worked. In addition, the challenge is I do not see 11/4/2021 like in the UI anywhere in the CSV export ALL ISSUES.
Thanks for the feedback. Please advise.
Hi Louisv,
I have advised, this is not a problem and is expected behavior. You can review Atlassian's Configuring Date and Time page or Contact Atlassian Support, depending on how much you disagree. Cheers!
