Hi, I want to use the project: Work Management - Task tracking which has all the fields I need except of Board options:
In software projects Board has: TO DO, IN PROGRESS, DONE
In business projects (the type I want to use) Board has: TO DO, DONE and missing IN PROGRESS
How can I add IN PROGRESS to Board?
Thank you,
Hi @Efi Ovadia ,
To add In Progress to the board, please following this:
Finally this is how it will look
Let me know if you have any questions or issues following this.
Wow, Thank you very much for your quick answer - it helped me.
Glad it helped you!
