We've created a work attribute in Tempo Timesheet. We need to add that attribute as a filter in the attached screens... Is it possible?
Thanks a lot!
In global Tempo settings (where management plugins) - check your cutom field to export
After export report to Excel and filter it by custom field.
In web - custom field you can add after grouping by worklog.
How are you all getting this to work though? I am grouping by worklog and cannot see any more attributes
I don't know if it's a new feature but you can add the work attributes to your Tempo report as long as you also add 'Group' by 'Worklog' - see screenshot
How to show the columns tab
Timesheet Reports and Gadgets for Jira Cloud now supports Tempo Work Attributes too, e.g.
Hi @Sandra Carrillo ,
You could use our analytics app Exply to create individual reports based on any work attribute or custom field that is available in your instance :) The clue - you can build your own reports/dashboards for projects, teams, and so on.
Feel free to contact us about anything :)
sincerely, Fabian from Exply
Hi, @Sandra Carrillo
Work Attributes cannot be used as filters in Tempo Reports (at this time). However, you are not the first person to express interest in this.
You may wish to visit the Tempo Ideas portal to see what others are saying on this topic and add your vote for this idea.
Meanwhile, as @Dmitry suggests, exporting your reports to a spreadsheet is, for now, a possible work around.
Hope this helps,
-dave
Here is the idea for Cloud - https://ideas.tempo.io/ideas/T-I-2105
