Hi
I am having a problem with my workflow. I created several statuses, like " system testing", "UAT" etc, and assigned them appropriately in the column management in my board setting. all statuses are working fine, except for "UAT", whenever i moved my status to UAT, I see a "done" check next to it. It's considering UAT as done.
I looked at my workflow diagram and can't see where the problem lies.
appreciate any advice. Thanks.
Hello @bee
Can you look at the post-function for this status, it seems that when you go to this status the resolution field it's updated automatically.
