In Tempo Timesheets, I would like to know if the number of workload schedule and vacation schedule that is possible to create in the app is unlimited.
Thanks a lot!
Hi, @Sandra Carrillo. There is no technical limit. However, there may be practical limitations in terms of performance considerations.
Hope this helps,
-dave
Hi Dave
No technical limits?
What will happen with try to insert in table after 2 147 483 647 ?
May be primary key in table will be cycled?
Primary key in table is INTEGER - i think limit is 2 147 483 647
