Workload per assignee
Shahrzad Shariati March 10, 2023
Is there a way to view workload of each assignee throughout separate team managed projects? I'd like to view how many tasks, story points assigned, and which projects they are across. I've created a filter already but it's not consolidated in a format that is easy to view.
Jack Brickey
March 11, 2023
Hi @Shahrzad Shariati , have you as yet played with using Dashboard gadgets? For example I might use the following filter...
project in (A, B, C, D...) and statuscategory = "in progress"
and then, depending on the number of potential assignees, I would pick a gadget to display by Assignee. If the number of assignees is small (<15?) I might use a pie chart otherwise maybe the two dimensional gadget.
Jack Brickey
March 12, 2023
@Shahrzad Shariati , You could use the two-dimensional gadget to show the number of issues by assignee in each project but what you don't have is the ability to display the sum of story points within that view. Options to consider:
Shahrzad Shariati March 12, 2023
Thanks so much for these options, I will give them a try and reach out if I have additional questions!
Re: 2nd bullet point using Jira-cloud for excel, I added the "add-on" to excel but when I went to connect after this step:
I get this page after I "accept"
What could be the problem here?
Jack Brickey
March 13, 2023
I'm unsure to be sure. I have not seen this before. You might contact Atlassian support.
Like Shahrzad Shariati likes this
Shahrzad Shariati March 14, 2023
My IT support helped me, this has been resolved. Thank you again for your help!
Nataliya Vasyliv_Reliex_
You can try ActivityTimeline plugin - it's a resource planning tool. There is a possibility to track users' tasks from different projects and teams, and see workload and story points (need to be set in configurations).
Nataliya, ActivityTimeline Team
Shahrzad Shariati March 11, 2023
@Jack Brickey With your example it doesn't associate projects with resource/assignee. Maybe I'm not following. My goal is to be able to view within all team managed boards: which projects each resource is working on what % of time whether it is in date/story points etc..
I have used the Pie Chart gadget but it only displays # of tasks each resource has.  Under "configure" in Pie Chart, I used "Assignee" as statistic type.
I'd like to see which projects and how long it will take for them to complete. Assignee is the focal point and list al that is associated with that resource. I thought about using smartsheets (?) but I would need to create a connector and I cannot do that if I do not have a project associated with it. I only have my JQL filter of all the resources and various columns I'm interested. The filter view in Jira does displayed I'd like.
i.e. imagine an excel sheet
                      Column 1 (total story points)     Col 2 (dates or story points)
Resource 1
    Project  (a) they are working on
    Project (b)  they are allocated too
Resource 2
Resource 3
