Hi everyone, i m trying to import test case in the trial version of xray but i have the same error over and over "Aucun demandes importé à cause d'erreurs". I need help please ;)
Hi @alognab
could you please provide some more details regarding your problem:
- how do you import your csv file? please describe your process.
- could you show what your csv looks like?
Best
Stefan
Thank you very much for your reply.
I use the test case importer available at project level to import my test cases.
Please find below what my csv file looks like, the mapping i dow and the error i get.
My goal is to present to my team the benefice we can get from xray to buy it.
Thanks for your help.
Best
Caël
This is the error in detail
"errors": [
"elementNumber": 0,
"errors": [
"xray": "No Test issue type found in target project."
"elementNumber": 1,
"errors": [
"elementNumber": 2,
"errors": [
Hi @alognab
it seems the specific xray issue types haven‘t been added to your project (at least that would be my assumption from the error message).
This could be done in the specific xray settings in your project settings:
https://docs.getxray.app/plugins/servlet/mobile?contentId=68386905#content/view/68386905
Best
Stefan
Sorry for the late reply. I did work!
I created the specific xray issue types in my project.
Thank you very much for your help.
Best Caël
Hi @alognab
Thanks for the feedback and great to know you got that working.
Please consider to hit the "Accept" button in order to mark this post as solved. That will make it easier for other users to find a solution in case they are faced with similar problems.
Best
Stefan
