Xray is not generating document
Rafael Tomazela Teodoro June 5, 2023
We have been using the Xray plugin for testing manager and when we try generating a report by Xray document generator, it didn't work. It showed just a 0% complete message during a long period of time and no error message was returned.
For example:
Xray - Document Generator
Xray is generating your document.
0% complete. Last updated at 05-06-2023 17:42:35.
Started 05-06-2023 17:37:16
Are you facing a similar problem like it?
Rafael Tomazela Teodoro June 6, 2023
Today Jun 06 the problem was fixed. Now, the report is working fine.
serge_billard
June 23, 2025
I had this issue, the support indicated that
"Please note that the limit imposed by Atlassian is not based solely on the number of Test Executions being exported. Instead, it includes all issues iterated during the export process.
While the template itself is working as expected, it performs iterations over: All Test Executions, the Tests associated with each Test Execution, the Test Runs executed under those Test Executions, any linked Pre-Conditions and any other issues linked to the Tests.
Some of these entities, such as Tests and Test Runs, are iterated multiple times within the same export. So when estimating whether you're within the limit, all of these must be taken into account. The total number of issue iterations must stay below the 1000-item limit defined by Atlassian."
Hope it helps.
However : Today I still have no solution. I will have to generate a manual report.
serge_billard
July 11, 2025
Hi
I encourred that issue, the only way I found was to generate document from the ticket in the time line instead of using the filter then generating a bunch of document at the same time...
Hope this help
Krishna Chaitanya
July 11, 2025
I am facing the same problem.. Its stuck at 5% in Edge browser and at 0% in Chrome browser. What is the workaround for this?
Pradeep Badwal
June 8, 2025
This issue has resurfaced the only difference is progress is stuck at 5% . xray.png
Martin Stirnberg [Communardo]
July 11, 2025
We are running into the same problem. We are trying to export 76 test issues to word/PDF, which are connected to few (if any) preconditions, test sets, set plans, and test executions, so we should be well below the 1.000 issue threshold. I'll be glad to check though - is there a log / protocoll that I can check?
Martin
gregory_panconi_external March 12, 2024
I am also facing same problem today
(Jira v9.4.14)
gregory_panconi_external June 22, 2023
Is there a solution to this problem?
Sreedhara Sarma Vummethala
June 13, 2023
