I am trying to import execution results into Jira using xray plugin in jenkins. In the import step ,if I use the endpoit as cucumber/multipoint then getting below error.
If I use the endpoint as /cucumber then no error and import is successful
Below error if using jenkins .
It was issue with the info json file. I figured it out thanks
How did you solved it ? Can you show an example of your info json ?
