Xray - when reporting defect in testrun, is it possible to select one step as bug details?
Brit Høvik Jørgensen
March 10, 2021
When we perform a testrun with a testcase with several steps and would like to report a defect i.e in step 7 of in total 10 steps the defect is created with a lot of details. The defect is created at step 7.
Is is possible to change a setting or use acommand  that only step 7 is included in the bug detail screen?  For the time beeing all the previuos step 1-6 and step 7 are included.
For some testcases only selected step should be included in the defect. (we remove the steps ahead manually as a workaround - and maybe thats what we have to do)
Thanks in advance.
Rogério Paiva - Xray Xporter
March 27, 2021
Hi @Brit Høvik Jørgensen
That is the current behaviour of Xray to show all the steps until the one it fails.
However, we would like to hear about your use case; please contact the Xray Support (http://xraysupport.xpand-it.com).
Rogério Paiva [Xray Support Team]
