Zendesk for jira add on
Administrador October 6, 2021
Hi Community,
We are trying to migrate Zendesk into our Jira proyect and would like to get the add on called Zendesk for Jira. Now, we are not sure which suppliers would be best for us and we are worried in case some of these do not follow the standards with are looking for...
Could you please help us guiding through?
Thank you
Sagar Mahajan
Hi @Administrador Welcome to the Atlassian community.
If you looking for Zendesk to Jira migration help or help with the plugin purchase or anything related to migration in Jira the based place is to check for the Atlassian trusted partner available in your location/country/city.
Atlassian partners will help you in this case, please check the below link to get the list of Atlassian partners in your locality and you will get their website details, contact details etc to reach them and you can check with all your queries with them.
https://partnerdirectory.atlassian.com/
Dima Lazarchuk
Hello there,
Our service can help you with the migration.
https://marketplace.atlassian.com/apps/1218450/zendesk-to-jira-service-management
Disclaimer: I'm the co-founder of this setrvice.
Hernan Halabi - Elite IT Consulting Group
Hello, as the other members suggest, check out partners in the partner directory. I would recommend checking for those who speak your native language. From your user I would say you are a Spanish speaker as is my case.
Laura Holton _ACE Rotterdam_
@Hi @Administrador 👋
Welcome to the Community! I completely understand where you are coming from but luckily Atlassian has done the hard work for you with their Partner Directory. You can hone in on partners with your own specifications such as whether they are a Platinum Solution Partner, where they are based, their services, expertise and more.
In addition we also offer a free guidance service to get you started and ask those all important questions without any further requirements. I'd welcome you to take a look here >> https://www.automation-consultants.com/free-consultations/
I hope this helps but if you have any other questions just shout 😃
All the best,
Laura
