Zephyr or Test Rail for test management
Abhishek Singh July 8, 2021
We have an enterprise addition of JIRA with 500 users
Need an add on only for 25 users for test management, most likely Zephyr
Is it possible get an addon only at cost of 25 specific users ?
or any other solution ?
Noopur Varshney [AIO Tests]
Hi @Abhishek Singh
As Sebastian mentioned, you will always be billed for the number of users on your Jira instance. But you can do a price comparison of different apps for 500 users and also the functionality that you need.
You can also check AIO Tests when you do a price comparison.
Noopur
Sebastian Brudziński
Hello @Abhishek Singh
Jira apps are always billed based on the number of users on the host instance. This means you won't be able to pay only for 25 specific users on a Jira instance with 500 users. You will see the price estimate for each app while you browse marketplace apps from your Jira environment (Apps -> Find new apps).
If price is an issue, you can check out the free test management tool - QAlity - Test Management for Jira that offers essential features to manage testing. At any point in time you can upgrade to QAlity Plus - Test Management for Jira with more advanced features, or switch back to the free version. Here's a high-level comparison of thee free and paid version that can help too.
Best regards,
Sebastian
FREE
