×Hi,
the use case is that i would like to update an issue field with some of its *specific* link issue type keys. for example, issue A is blocked by issue B and relates to issue C.
i want an issue field of A to contain the value B but not the value C.
im using this in the json edit:
"fields": {
"customfieldName": "{{#issue.issuelinks}} {{#if{{equals(type.id, 10002)}} {{inwardIssue.key}} {{/}}{{/}}"
i know that 10002 is the correct id that i need. i checked the json view of the issue, and also printed the type.id into the log.
however, using the syntax above, it doesnt add the relevant key.
Hi @ben friedman,
Does the following rule meet your needs?
Looks like it does what you need:
Hope this helps!
- Manon
@Manon Soubies-Camy thanks for the reply, but not quite.
i need to have that update on all the existing issues in the system that are already linked.
The trigger cant be for a current linking that takes place.
I have a manual trigger, that for BRANCH ISSUES: jql for epics + tasks != closed status.
i cant use another branch of linked issues within the original branch and i have to use the original branch to cover the existing issues.
thats why i wanted to use the json approach to pull information into the issue's UI.
So would it work if you used a scheduled trigger instead of a manual one? It triggers the rule from a JQL query and then you can add a branch. You also can manually start the rule by clicking on "Run rule". Not sure to understand the functional need behind your question so my suggestion may be irrelevant.
actually, the JQL under the scheduled should do the trick i think!
@Manon Soubies-Camy im actually hitting a problem.
im getting only 1 value on the blocked issue and not a list from all the blocking issues. the blocked issue ends up with 1 blocking issue in the text field.
in the last action of edit im using ' {{issue.blockers}} {{triggerissue.key}}'
i think that this is since the blocked issue is empty at the beginning and all blocking issues use that instance. i tried to to refetch issue within the FOR, but that didnt help.
