agile board column for different issue type with different transition
mnpiad
i am using JIRA cloud
we have one custom issue type which have transition from submitted--assigned–development ---testing–complete
we are also using default story/task/epic issue type they have there own default workflow transition  todo–in progress-done
we have an agile board where we use epic and use issue type custom or story
how do i setup a column in board setting for mix issue type ?
right now i can setup column as below
submitted--assigned–development ---testing–complete ---todo—in progress---done
can i separate out by issue type workflows ? like
todo—in progress—done
-Thanks
Nic Brough -Adaptavist-
February 7, 2017
A board does not care about the issue types.  Each column is a status or group of status, nothing else.
You could have a board with one column for every one of your status, but that might not flow too well as issues would not be able to be dropped into all columns and that's not too clear to users.
I think your best bet is "groups of status".  Set up something like
submittedassigneddevelopmenttestingcomplete
submitted
todo
assigned
development
in progress
testing
complete
done
One issue type will follow the columns, the other will only allow for three of them
