assignee name in filter query changes to numbers
Amir Primov May 17, 2020
When I assigne = name , it automatically change that to assigne = qp9862308756248756
I saw that I need to check my prifile in id.attlassian.com but muy profile have both full name and public name ,
Any thoughts ?
Ollie Guan
Amir Primov May 20, 2020
I see some option presented at the end of the page to "insert accountid " or " resolve users "
I do not have these 2 options
Mike
What genius decided this was a better representation that simply keeping user names?
I have filters to track the work assignments of my team, which frequently changes staff,  How am I supposed to know which 24 digit account number to remove?
Like • 6 people like this
Panos
August 14, 2020
I have only been able to use this url /jira/people/5b560b3097e6062cc4b76b88 to figure out what number represents what person
Like • Elizabeth Jones likes this
Karl Rohde
This is a major issue. I agree with Mike that this presents a challenge to overcome. This should be looked into. It makes using "assignee" in a JQL filter a significant frustration.
Like • Jay Lee likes this
Daniel Krauthgamer
October 25, 2020 edited
The only workaround I found so far - is switching into basic mode
This will change the assignee field into a dropdown menu where you can choose your team members.
Mike
I see no difference when I click on Switch to Basic.  The id's in the JQL remain the long alphanumeric ids.
What was the reason for switching from names to these unrecognizable alphanumeric IDs?
Since this week I am now also getting these IDs in my CSV extracts, thought they are not included in my column selections.
Please restore the names instead of this jibberish
assignee in (5da94ec22016b10c337add5c, 5f6b4aadd33d7600774c808b, 5e66638677d46c0cf93ace0a) AND Status
Like • 8 people like this
Ibrahim Ghalghay
use the property displayname
like assignee.displayname in (John Smith, Anonymous)
Mike
I do not understand the format you are suggesting.  What is the format of the assignee?
I have tried using the actual email and also tried using the default and appending .displayname.  For either I get an error message.
assignee in (mike.bischof@publicissapient.com.displayname)
Error in the JQL Query: The character '@' is a reserved JQL character. You must enclose it in a string or use the escape '\u0040' instead. (line 1, character 26)
assignee in (mike.bischof.displayname)
The value 'mike.bischof.displayname' does not exist for the field 'assignee'.
Ibrahim Ghalghay
I meant
{{issue.assignee.displayname}} in (first name, second name)
you might have to enclose the values between double qautation marks
Like • John Sutton likes this
Ibrahim Ghalghay
@Mike please advise, did my above mentioned answer solved the issue?
Ibrahim Ghalghay
@Amir Primov please advise
Clifford Hull
@Ibrahim Ghalghay Worked for me. Thanks!
Like • Ibrahim Ghalghay likes this
julia casagrande February 6, 2024
For me dosent work
Tom Fuller
February 6, 2024
I get around this issue with a query like this:
Type in (Defect, Task) AND Assignee in ("Tom.Fuller@Google.com") ORDER BY created ASC
Works for me. :)
Help us plant more trees
