I have searched for the solution to this but just have not been able to figure it out. I want to have rules as an issue transitions that the assignee is changed to the value from another custom field. There is a custom field for Developer, Tester, Approver etc. I have not been able to reassign the assignee field. I am sure there is an easy solution to this but have not been able to figure it out. Can someone tell me what action to use and how to enter the value?
OK. I have the answer...
You Assign Issue, and select Smart Value.
But you write it like this...
{{issue.[custom field name].accountId}}
eg. {{issue.editor.accountId}}
I also think this will work too...
{{issue.customfield_XXXXXX.accountId}}
Hi @John Funk,
I want to be able to do the opposite i.e. edit a custom field to copy the assignee when the status of an issue changes. Should I use trigger issue or current issue? Doesn't seem to be working.
For e.g. If Bug changes from To Do >> In Progress Then Custom Field == Assignee
Do I use smart value and pick {{issue.QA Resource}} ?
This is my understanding too, as in here: https://community.atlassian.com/t5/Jira-Service-Desk-questions/Automation-for-Jira-Change-the-Assignee-from-a-custom-field/qaq-p/1398101 but it doesn't work for me.
Hi Scott,
Do you have a rule built already using Automation For Jira?
If so, use the Edit Issue action and not Assign User action. Then Select Assignee and copy the value from another field.
I would just use Copy from Current Issue.
Then click on the words Current Issue and that will give you a popup where you can select the QA Resource field.
Here is what I have so far. Will this work?
Business Sign-Off
{{issue.Product Owner}}
@John Funk I don't see how Edit Issue action would work as it does not let me update the assignee field to a value from another field on that same issue.
Hello @John Funk ,
I'm having the same issue.
When I select Edit Issue, and Copy From Issue, the fields available are only:
No custom fields available.
However, when I change to Assign Issue and select Smart value, I can add some smart value content like {{reporter}}, but I want to use {{issue.Editor}}, but it isn't working. Even when I use the custom value too, like {{issue.customfield_XXXXX}} I just get an error.
It would appear possible here: https://community.atlassian.com/t5/Jira-Service-Desk-questions/Automation-for-Jira-Change-the-Assignee-from-a-custom-field/qaq-p/1398101 but I can't get it working.
Any help would be much appreciated.
Hey Joe - It's probably because the field is not available to either the project or the edit screen. Check the field Owner to see what is different about it because it is a custom field, too.
Hi @John Funk I thought this might be the case too. But I wasn't sure because this is a Next-Gen project, and created via the project settings interface which means the field is automatically in the project edit screens on the board etc.
I added my way around it below.
Would be good to get a little clarity as to whether or not this is the only way?
Hey @John McKiernan - can you bring any clarity to the custom fields for Next-gen not showing as available to copy to the Assignee field?
@Joe Hankin - Isn't the Owner field a custom field? What's different about it than the other custom fields that aren't showing?
Hi @John Funk
Yes this is in fact a custom field. But it wasn't set from inside the project, it seems to have been setup at a high level. Is my work around below not an easy way around it?
Here are the details on the custom field called Owner.
Default Configuration Scheme for Action Owner
Default configuration scheme generated by Jira
This field will be available on issues of any typein all projects
If your work around does what you need it to do, by all means use it! :-)
But it shouldn't be that difficult and you shouldn't have to use smart values as your only option.
Get your free all-access digital pass and don’t miss groundbreaking announcements, brand new features and product updates, insight-packed sessions, and exclusive digital content.
Sign up
