automation: search for subtask with same parent
Dominique
When a certain subtask is created, I want it to be linked to its "sister/brother" subtask that contains a certain word in the summary. So I need to find subtasks with the same parent.
I want to make a new branch  in the automation and there I want to use JGL but what do I need to write in there?
For the certain word I use
summary ~ 'Anhang' and ....
can someone tell me waht the second part looks like?
Thanks in advance!!!
4 votes
Charlie Misonne
Hi Dominique, welcome to the Atlassian Community!
Can you try this JQL query in you automation branch?
summary ~ 'Anhang' and parent = {{issue.parent.key}}
{{issue.key}} is a smart value and references the parent issue key from the issue triggering the rule. So if your new subtasks triggers the automation parent = {{issue.parent.key}} will return all issues from the same parent as you sub-task
More smart values can be found on Smart values - general
I hope this helps!
Dominique
the jql section does not like the {{ }}, so when I go on "check query" I can not select it, only when I delete them but that does not work. is there a workaround?
Charlie Misonne
But you can save the configuration without pressing "check query" right?
I think it should work like that, it has been a while since I tried this.
Like 2 people like this
Dominique
YES, it works!!! Thank you very much!
Like Charlie Misonne likes this
Charlie Misonne
You're welcome! Glad I could help!
Like Dominique likes this
Karolina Dylewicz April 6, 2023
thanks man! it works :D
David Ciran January 12, 2024
Hi @Dominique Hermens,
Firstly, I am aware of the fact you already solved your problem, however, I would still like to mention an app our team developed for similar issues.
If you are fine with a marketplace app, we have created Subtasks Navigation app to view your sibling issues and their description without loading the entire parent nor using the filter. I know it does not exactly answer your question but still it might be a good addition to your toolkit, allowing you to easily find subtasks with the same parent in a new panel called Other Subtasks (view the picture below)
Disclaimer : I am part of the team which developed this app
Subtasks Navigation for Jira
Dominique
Hey David,
thanks for that, unfortunatelly I do not work with Jira for the moment (new job). But I guess this could help others 👍
Kind regards
Dominique
