automation to receive an email - 50% of the estimate has been consumed,
Michel van de Wiel October 17, 2023
I would like to set up an automation to receive an email every morning containing all tasks where 50% of the estimate has been consumed, divided per project. The following has already been configured, but it is not working correctly.
Trudy Claspill
Hello @Michel van de Wiel
In what way exactly is it not working correctly? Are you not getting an email? Is the content of the email not what you expect?
Can you show us the Audit Log entry for the execution of the rule?
Can you show us the details of the Trigger component?
Can you show use the details of the Send Email action?
Hi @Trudy Claspill,
Sorry for the not compleet information!
  • I do not receive an email
  • screenshot-proplanet.atlassian.net-2023.10.17-19_16_38.png screenshot-proplanet.atlassian.net-2023.10.17-19_16_44.png
Trudy Claspill
Can you show us the details of the "When Scheduled" Trigger component?
Here you go:
Trudy Claspill
Your trigger component is not selecting any issues, and you have no subsequent steps to select issues.
The rule has no direction from you about the issues that are of interest. You have two ways to do that.
You can add a JQL to your trigger (see the check box at the bottom?) to select the issues of interest. You can actually incorporate both of the Conditions you specified into that JQL
originalEstimate > 0 and workratio > 50
Then you don't need the Condition components.
Note that when you use a Schedule trigger with a JQL the actions in the rule will be executed for each issue found. So you would get an email for each issue returned by the JQL statement.
Alternately you can not have the JQL in the trigger and instead use a Lookup Issues Action to execute a JQL to retrieve a set of issues.
With that action you could send one email that lists all the issues found.
https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Lookup-issues
Like • Bill Sheboy likes this
