board of archived next generation project still visible
Sebastian Ovide July 29, 2020
Hi
I've archived a next generation project. The project is not visible anymore which is great.
But the board it is... It looks like a bug... Just click on "search" and then in the bottom tab "boards"... a list with the existing boards (Not the projects) will appear, including the archived next generation project.
Any ideas ?
Jack Brickey
Sebastian, can you educate me on how you archived the project? While I am aware that project archiving has been a recent addition for Cloud Premium I am not aware of being able to do this in Standard. But, as I don't use NG very much maybe there is something there I'm unaware of. Regardless, assuming there is some sanctioned archiving going on here I would expect the associated board to archive. One exception - if the board you are seeing was not the default board associated with the NG project but rather a custom Kanban board created for the NG project then I could see where it would not be 'archived'. In that case deleting the board would be in order.
again, a lot of speculation by me at this point. :-)
Hi Jack. Thanks for the answer. Just to confirm that we are using the premium....
Jack Brickey
I see. I was unsure as the Product Plan tag on this post says Standard. In any event, I can't say for sure as I do not use Premium. I would reach out to Atlassian Support. Given how new archiving is, I would not be surprised that there may be some holes.
Like Sebastian Ovide likes this
you are right Jack. I've just contacted them. :)
Like Jack Brickey likes this
Jack Brickey
Excellent. please update us here. As you are on the cutting-edge of archiving I'm sure others will be interested in your findings. :-)
