cannot add created custom field to a issue
Matias Costa Meneses November 9, 2020
I had created a custom field in an Next-gen software project, the idea its that these custom field not be visible, becouse i want to have a field with non-visible data, and then capture these data with the api rest.
Well, having said that, i clicked on settings => issues, and i create my read Only custom field.
But i can´t associate it with the project,  and it doesn't appear visible when I create an issue.
I see that on clasic projects these works fine, but i need on next gen project,
i´m using scrum template.
anyone have any idea how can i do this?
Sorry for my english, i speak spanish
Jack Brickey
November 9, 2020
You can’t create custom fields in the classic sense and apply to a NG project. You can only add fields under the project settings > issue types within the project itself.
hello Jack, thanks for the answer,
Yes, i know that, my question is how can i create and put a non-visible field in the next gen project. I think that this it not working
