cannot link epic to legend
Jin Wu
hi there,
i cannot link Epic to Legend, i can't see parent link in epic property.
Thomas Hardin
Hi @Jin Wu ,
I'm assuming that Legend is an issue type? And are you referring to the Advanced Roadmaps Parent Link field?
If so, you may need to do a few things to enable this:
1. Go to your Hierarchy Configuration
 Hierarchy Menu.png and add the Legend issue type to the level above the Epic Hierarchy Config.png
2. Go to the screen scheme configuration for the Epic in the respective project and add the Parent Link field to the create/Edit/View screens as necessary. Epic Screen.png
Now, you should be able to see the Parent Link option on your Epic.
Once again, I'm presuming that you are referring to Advanced Roadmaps and an issue type.
Register today
